Was doing a little spring maintenance and took the cover off my Alde tank compartment and found a puddle of coolant and signs of frequent leaking. Upon checking the lid I found the lid was only screwed on a few turns and the sloshing going down the road caused it to leak from the lid often. Tightened it snug and added to list to recheck.
2022 T@B 400 Boondock (~21,000 miles) as of 10/07/25
2022 - 11 trips - 34 nights
2023 - 4 trips - 21 nights
2024 - 5 trips - 51 nights
2025 - 5 trips - 18 nights
2024 Ford Ranger Raptor (10.5 mpg towing avg)
2018 BMW X5 xDrive35diesel (15.6 mpg towing avg)
2020 Toyota Tacoma TRD Off Road (11.1 mpg towing avg)
0 ·
. . . Adding a tight turn or two of electrical tape to the neck threads of the reservoir can tighten the fit of the reservoir cap if it is loose. . . . .
Originally posted by @tybladesmith, Oct-2021. Original Thread here.
Adventures: 58 Nights: 405 Towing Miles 50,180
While 'plumbers' Teflon tape should do the job,
the advantage of 'electrical' tape is that it will last far, far longer.
Every time you remove the Cap/Lid when plumbers tape is used you will have to install new tape (plus remove the damaged old tape) . . not so with heavier electrical tape.
