I have no direct knowledge . . . based on Factory Tour pictures and how the 320S (black tank models) were done . . . First place to look is the CoolCat Cabinet.
FYI. I found the sensors using a mirror. They are on the forward right corner of the tank. The sensors (screw heads) looked pretty clean, even though I get erroneous full readings. Hopefully a long soak with concentrated Happy Camper will resolve the sensor issues...
Horigan said:
. . . I get erroneous full readings.
The KIB style/brand are well known to provide poor/bad tank levels. It is a shame nüCamp switched to KIB instead of keeping the SeeLevel System (SeeLevel was not 100% perfect but far better than the KIB style).
If you want to know more about how the KIB Tank Monitor works, here is a helpful video
RV Tank Monitor Panel Gives Bad Fill Level Information
