2008 TAB WATER PUMP ELECTRICAL DIAGRAM
1Jack_Diane2
1Jack_Diane2 Member Posts: 3
I traced all of the wires to help troubleshoot a water pump not working.  I hope the attached diagram helps others.  It all makes sense now that I’ve drawn it but having two white wires going to the pump was initially confusing.
My problem turned out to be the electrical switch at the faucet.  I think the high current from the pump arced enough to cause the switch to fail.  I’m going to add a relay at the faucet switch location to help prevent this in the future.
