Anyone know the wire color and location for Boondock backup lights?
crosstrnr
Member Posts: 24
2019 320s Boondock Edge. Trying to connect the existing backup lights to the 7 pin so they come on when TV is in reverse. They currently operate via a switch.
Does anyone know the location and wire color of the wiring for these lights? I’m good on the J box side. Just need the other end.
TV is 2007 Kia Sorento EX with 3.8L engine
@crosstrnr, I can't answer your question (although the usual standard color at the seven-way plug connection is yellow, but I have also seen purple), but I am curious if your 2019 320 S came with reverse lights from the factory. Mine did not, and I am not aware of any having them in that model year. I am also curious where they are located. Maybe you can post a photo. Thanks!
Thanks, @crosstrnr, I now see what you are referring to............the lighting included as part of the Boondock Edge package, which I am familiar with, but did not purchase.
Should be the center pin coming off the 7 pin connector. Not sure it's actually connected to anything in the junction box under the tongue or for that matter, tow vehicle.
2021 T@B 320 S Boondock
2025 KZ Sportsmen 130RD
2025 Ford Ranger
Can you look at the back of the switch and check the wire color there?
Nice, I have not seen that before. Is it factory or (previous) owner installed?
As for the wiring, switches must be connected to the Fuse Panel.
My guess is; You would need to run a new wire from J-Box to light side of the Ext Rear Switch.
Adventures: 50 Nights: 415 Towing Miles 50,6502 -
Just a thought but I prefer the manual switch backup lights the previous owner (@Dalehelman ) installed. Otherwise if you're pulling forward trying to adjust the angle you don't see when the trailer is lined up.
