My old Wrangler does not have an isolation relay, so if I leave the 7 way plugged in over night the higher voltage lithium will back feed into the AGM to balance the batteries. Is this a correct statement? If so, is there a risk of damaging the AGM by over charging? What about while driving?
0 ·
I don’t have any empirical data, but I’m 6 weeks out on a trip with two lithium batteries and a Jeep GC. I have not observed any flow of voltage/current in either direction. I have observed no voltage changes other than what is normally expected . I’m sure there is something however small, but nothing to show via smart shunt or voltage readout on vehicle .
Southern Maryland
There should not be any great harm by having them connected, but the two battery types do not have the same resting voltages or characteristics. There will be some kind of current flowing most likely from the LiFePo, but unless one or the other is seriously discharged it won't be too much (not based on measurements, but just thinking about it).
Jericho, VT
Silly question, but doesn't the TV have something like the Victron's float mode to maintain, but not over charge.
