Permanent doohickey to hold door latched when using Keder rail awnings.
All of us have some workaround for the door to awning interference when the door needs to be latched open. Does anyone have a fix that is clean in design that latches the door open AND easy to unlatch like the existing one? I'm thinking like a receiver that is offset from the side of the trailer or a similar idea that extends the door pin? I'd be worried about catching something (like me) if it sticks out to far however.  You get extra points if it is hinged so its awning use selectable...
managed by VE Smart Network
