My 2022 Tab 320s Air8 stopped working. I can hear the compressor come on, but it doesn't cool. There is no condensation flowing under the camper. The camper is 19 months old, stored in garage since purchase, 300 miles on it, mostly used heat.
Checked everything I can. Fuses, circuit breakers, temps , panel etc. Any ideas? I wrote Nucamp and explained the situation. In short they quickly responded and said... Sorry to hear that, check to see if the unit is dislodged, if not call your dealer or call Elwell.
Air worked less than 2 months prior. Open to any suggestions. Otherwise it's a 200 mile drive to Austin and probably a 2 month wait for service based on the postings I've seen.
0 ·
2022 T@b 320 S / 2021 Subaru Outback
Southern Maryland
Also, here's a link the manual for the Truma unit (in case it has any info you didn't get from Elwell)
Also, no callback from Elwell tech today either.
Southern Maryland
2020 320S Boondock Lite (silver w/blue)
2019 Subaru Ascent Premium
Southern Maryland
I’m not quite on the fence that they are unreliable (yet). ACs are mechanical parts and although we expect long trouble free life, sometimes even good systems fail (also see it in cars all the time..right ). As most of have concluded, Elwell is most likely just a distributor with their name on it. Even most home AC units are made by only 5-6 companies, but are rebranded by many others, with sometimes lesser quality parts (boards and compressor).
Southern Maryland
I have an update on my Air8 situation. We drove the our Tab320s back down to PrincessCraft RV in Austin on July 6th for service on the Air8. The status as of July 20th is as follows - Service has checked the unit and found that the Air8 blows air and the compressor comes on so probable internal Freon leak. Unit needs to be replaced. They have a call into NuCamp and are looking for a replacement. Since this appears to be a defective Air8 unit barely out of warranty I requested it be covered. If not it will be an expensive fix. PrincessCraft RV says it is up to NuCamp whether they cover the unit or not. Lets hope they stand behind their products.
Ideally IMHO, nüCamp should have buyer options:
+-+ Air8 with Microwave
+-+ Window A/C without Microwave (with hopefully improved fresh air venting for A/C unit)
Having these options is not a huge production scheduling/planning or inventory control issue . . .
And if we look Big Picture, IMHO there should be a Cassette or Black Tank option as well.
I'm a hard user of recreational equipment (and sell my used items well below 'used only three times' units). In the next couple of years my '18 320S will need replacement and while it is an ideal size and floorplan for my usage - - - nüCamp is not on the replacement trailer wish list . . . due to Air8 and Cassette.
