E brake switch and electrical system short?
Bracha
Member Posts: 33
This past weekend I was boondocking for three days.. the fuse on the group 24 battery (I have a 24 and 31), blew on day 3. Since then, when I turn bat cut off switch on, the fuse blows. I also cannot have shore power unless the converter fuse is out and it is not blown. Could these problems relate to the e brake switch?. I was checking the brakes and I am having a hard time pulling the pin out and the switch looks damaged a little melted...
Possibly. If the fuse at the battery blows the short is very likely before the power center because everything downstream of the PC has its own fuses. So that leaves the wiring from the 7 pin to the distribution box under the front, the emergency brake switch and wiring to it, or the wiring to the power center.Should be easy to figure out with a multimeter.
Can a faulty break away switch cause these problems?
I give up. My camper is useless. I cannot find a qualified person to do repairs
For $11 you can take a chance on a new switch to get your trailer back.
https://www.amazon.com/CURT-52010-Trailer-Breakaway-Switch/dp/B001GN6QQW/ref=sr_1_6?crid=V2RC3LUO2AMQ&keywords=trailer+breakaway+kit&qid=1686347417&sprefix=trailer+breakaway+,aps,139&sr=8-62019 Tab 320 CSS, 2019 Ranger TV, OH -
Hey everyone - @Bracha’s electrical problem is being handled on another thread. Let’s concentrate our efforts over here:https://tab-rv.vanillacommunity.com/discussion/17247/blown-battery-fuses#latest
Thread closed to redirect our help.
SharonSharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
- 920 Introductions
- 74 Teardrop Groups & Links
- 915 Tips & Tricks
