My son is traveling in his 2023 Tab 400. Yesterday, they stopped and fixed supper and floor and rugs were dry. They continued driving in hard rain and when they got to their campsite late last night, rugs and floor were wet all the way to the battery area. There was also some water in his storage compartment.
I am thinking water was blowing in the air conditioner area and getting in the camper. (I have a tab 320 cs with the air conditioner on the floor and this has happened to me.) He did not have the snap on cover on the AC because he wasn't sure you could drive with it on.
What are your thoughts as to where the water came from? Can he drive with the snap on cover on his AC?
With the storage compartment - I am thinking door seals not placed correctly???
Any help would be appreciated as he is traveling for the next couple of weeks with his family.
                1 ·
I had the same thing occur last October (in our 2019 T@B 320 S Boondock Lite.) A lot of water was coming in through the base of the side door opening at the lower corners of the door opening. We caught it early, so were able to mop up the water before it did any damage, but it happened a few times during the very heavy storm we travelled throught. I determined that the door seal was not properly sealing those corners, plus the aluminum trim of the door at those locations was not pressing inward toward the door frame to help apply pressure to the seal in that area. I had our trailer at nuCamp to replace the defective floor and they replaced the door seal. I also added some small corner door frame seals, like are commonly found on a house garage entry door or side door (small square seals), and those actually seem to have resolved the problem even better than the entire seal. They basically double the width of the seal in those corners. To see if that may be the cause of water penetration in your trailer, have someone observe from inside the trailer (while darkened) while you shine a bright light from outside toward the area of those corners to see if light penetration is visible. See photo below.
I also had water coming in through the rear side storage compartment door. nuCamp replaced that door seal as well with a better/thicker one. The opening between the two ends of the original seal created a small gap and was located at the bottom center of the rear side of the compartment door opening (see yellow arrow in photo below.) When nuCamp replaced the seal, I believe they positioned that gap at the rear left side of the compartment opening, which resolved the problem, although not completely. I will just keep an eye on both seals if we encounter heavy rain during future trips. Here's a photo of the original seal. I will be picking up my trailer from storage today, so when I get a chance, I will post a photo of the new seal.
He has a call into NuCamp and he is going to check all water lines and do the door light test when he gets to camp today.
In the second photo, the red arrow points to the new location of the cut ends of the seal. They are on the rear side of the compartment opening, plus the ends meet together (no gap like the original one.) The seal is thicker as well.
however, in general it happens with older rigs as the various sealants fail.
On my rig it was the sealant around the wheel wells - - - - -
I could be parked at a campground in a pouring thunderstorm and the trailer (floor) would be 100% dry . . . . but drive down a wet highway in a light rain and it seemed gallons of water got sucked up into the trailer . . .
{which is not watertight}
