Smart Tv
kevenv
Member Posts: 27
2022 Tab400. I don't Boondock. Is there any reason I can't replace the 12volt Jenson with a normal 110volt smart tv? Thanks.
I don't see why not as long as you account for where you will plug it in and ensure the new TV is mounted properly and securely. I use a firestick with my stock TV in our 320CS-S to stream. Cheaper then a new TV and I don't have to worry about unintended consequences of modifying the stock build.
2021 T@B 320CSS Boondock - "Chirping Bird"2018 Chevy Colorado - "Dad's Truck"3 -
My 2022 Tab 400 came with a 110v Jensen TV that plugs into the inverter outlet below the TV. Thought I read somewhere on this informative site that the 12v TV went away a model year or two earlier.
2022 T@B400 BD behind Toyota Highlander XSE
Yes, yes it did this last year
cheers2018 TaB400 Custom Boondock, Jeep Gladiator truck, Northern California Coast.1
