I have a 2020 T@B 400. It's been in storage for about 6 months. Getting ready for a long trip a few days ago, I noticed that the power inverter by the door was buzzing. It had somehow inadvertently been left on, the light on the panel shining, since our last camping trip. (The battery switch in the back storage area was OFF the whole time!)
I turned off the inverter, turned the battery switch on and checked battery strength on the T@B display by the door, which said "low" battery, even though there is a solar panel on top, and the interior display for that was showing that it was charging: battery status "low". I checked back the next two days, the inverter off, the solar panel still charging and the battery status was still "low".
Today, I drove for 550 miles (connected to the truck, of course) and the battery status is still reading "low". The inverter was off the entire trip.
I was very much hoping that the long drive would have charged the battery back to full again. But nope, according to the T@B panel by the door. The interior display for the solar panel agreed: "low" battery.
So what have I done?
And why was the inverter even powered, when the battery switch in the storage area was "off"?
0 ·
With the battery switch on and driving for 500+ miles plus solar you should have gotten some charge back. There is a good chance the battery is indeed dead. What likely happened is the inverter slowly drained the battery and during the day solar only got a small charge into the battery. So the next night the battery got drained to almost nothing again. That kills a battery quickly.
The "smart alternators don't charge RV batteries" claim is bogus. If you parallel an almost dead battery with the vehicle battery it pulls down the voltage enough that the alternator increases its output. Even if the smart alternator is in its happy place it will still output around 12.5V, enough to breathe some life into a discharged battery.
