Alas, the pump, and/or the pressure switch may have finally given out on us.  On-board water tank is full, fuse is good.  Pump makes no sound as it usually does to build up pressure, nada!.     I'm guessing that the pump or the pressure switch attached to it has gone bad.   Prior to removing the pump, what would be the best way to insure that 12V DC power is, in fact, getting to the pump?   In researching the Artis pump PDSI-130-1240E, it would appear that regardless of whiter it is the pump or pressure switch just replacing the entire unit would be the way to go.   Replacing it looks to be pretty simple, but I'd like to make sure there is 12V DC getting to it before ordering and replacing it.  Advise on testing it or experience in replacing the unit would be most appreciated.   Thanks Tabbers!
Thanks for any help.
North Carolina
2015 T@b Max Q
North Carolina
2015 T@b Max Q
