After nursing a degraded lead acid battery to the end of last year's camping season I decided to move into the 21st century and install a LiFePo battery. However I'm frugal (some might call it cheap
) so I opted for one of the lower priced batteries on Amazon, sold by Vatrer. I picked it because it has low temperature charging protection (as verified by Will Prowse) which actually is a concern around my neck of the woods (high desert with hot days but chilly nights). The joke around here is you can go from heating to air conditioning to heating in a single day.
I've used it for 2 months now and have done a few full cycles confirming the battery can deliver the advertised 1280Wh/100 Ah. However this is highly dependent on charging method. I've used both the older non-LiFePo converter and a 200W solar panel with a LiFePo capable controller. With the converter the battery got to 1180Wh capacity, with solar charging and the battery switch on it only got 10Wh more. The only way to get a full charge was to turn the disconnect switch off and allow the solar charger to have full reign of the battery. I found that somewhat interesting because the standby power draw of the trailer is just .3A. Need to chew on this a little more as to why the small power drain affects the total charge amount.
The battery does not have any built-in bluetooth capability so it is important to monitor the amount of power drained from it. Voltage is not a good indicator as I found out, went to bed with 12V give or take and woke up with everything dead because of the low voltage cutoff. The good news is that the propane/CO detector never started chirping because the voltage never drops below the warning threshold before turning off completely.
These are two Enjoybot batteries ($350 each). I could have run with one 100AH and not had a problem running the fridge, lights, stereo/TV, and pump for that whole rainy week. On the worst day it would have only been down 30%.
2025 KZ Sportsmen 130RD
2023 Ford Maverick XLT
The Finger Lakes of New York
WF8735/P - Not for lithium batteries (charges to 80%)
