Just me, but this not a full size rv with a 600lb tongue weight. My previous Jayco had one, it was actually slower than cranking, and you only 130lb or there abouts.
I’ll add that from this solo disabled woman’s standpoint, I found the stabilizer jacks much more tiring to crank than the tongue jack, probably because there are four of them. For those, I use a drill & socket.
Some folks have altered the tongue jack to be “powered” by a drill and socket as well, and there are instructions for that here on the forum. If I camped more frequently, I’d probably do that.
2019 320s BD Lite, white with blue (“Haven”) 2015 Subaru Outback 3.6r (unsafe 200lb tongue weight limit until 2020 models) 2020 Subaru Outback XT Pacific NW
@Tross2023 A few months ago Jenn Grover did a video about an Ultra Tow electric tongue jack that she installed on her 320. It has a plug that goes directly in the 7-pin jack on your tow vehicle, so no wiring is needed to be done for the installation. We purchased the 3500LB rated one for our 400 and used it on a long trip, so feel ready to review our experience. Install was pretty easy. It did require some work from a half-round bastard to get the post to drop in the hole (that's a file, I'm not talking poorly about my spouse). I believe the install in the video had the same issue. Using the jack, the TV does need to be close to trailer to provide power. While unhitching (for example) this was a bit annoying. Raise the tongue, pull forward a few inches and lower the tongue, then disconnect the electrical connector from the 7-pin. For us, one of my 'things to do' post-trip is to wire the jack to the trailer electrical to bypass this minor inconvenience. Ultra Tow does also make a version that wires directly to the trailer. The jack lists through Northern Tool and Amazon for $190. We happened to catch a sale on Amazon and purchased for $160 in early May (a week before we left on our last trip). The 'Amazon version' shipped from Northern Tool, by the way. Enjoy outfitting and using your T@B to suit your needs!
2023 TAB 400 Relentlessly Pursuing a Silverado EV 'Racing the Wind and Chasing the Sun' Virginia Beach, VA
Minnesota and Arizona
Virginia Beach, VA
