Rearview Camera Install
dcolden
Member Posts: 10
Working on installing a rearview camera on my 2022 T@B400 BD. While searching for information on rearview camera installations. I ran across a comment from TabberJohn referencing this thread, https://tab-rv.vanillaforums.com/discussion/4020/. He indicated that it could save time and energy by cutting the experimentation phase. The link gives me a 404 error. Was wondering if someone might know where to find this thread?
It appears for me that the spot to mount my camera is on the top of the rear bumper above the T@b logo. Does anyone know how this trim is attached at the top? I found the 8 screws along the bottom edge. It appears that there is a full length piece of butyl rubber tape at the top, but is the metal strip below it a cleat that the trim piece fits into some how or is it just a place for the butyl rubber tape to adhere?
Thanks for any info.
2022 T@B 400
2018 Chevy Colorado Z71
Indianapolis, IN
Indianapolis, IN
Grumpy_G said:Here you go: https://tab-rv.vanillacommunity.com/discussion/4020/Thank you for the link. I see the difference in the URLs. Things changed in the last 6 years.2022 T@B 400
Indianapolis, IN -
exactly where I installed mine. Removing the bed in the interior and one piece of panelling, you can easily access power from the lights and there is already a through-hole you can pass power from the inside easily. The cover in the back has some screws in the lower cowling, and then some mastic-like glue holding it to the body. You dont need to fully remove it, just open it wide enough to get your arm there.
2023 TAB 400, towed by 2001 Ford f-150 Supercrew XLT 5.6 liter v8
- 920 Introductions
- 74 Teardrop Groups & Links
- 915 Tips & Tricks
