Keder rail vinyl insert
den
Member Posts: 8
Any one sourced replacement vinyl insert for the Keder rail on TAB 320 Mine have started to split
No. Most folks remove and discard. Maybe find a dealer and ask a new buyer for theirs.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
Maybe you meant the vinyl trim next to the keder rail that covers the many screws holding the aluminum trim. If so there's this: https://www.amazon.com/dp/B0031Y7Z1Y/?coliid=I2US4II0GKRQG2&colid=23XRNPET3DJOB&psc=1&ref_=list_c_wl_lv_ov_lig_dp_it2019 Tab 320 CSS, 2019 Ranger TV, OH0
THis is the vinyl insert0
That is the Keder rail insert. We still have ours in place. We have a CS with different trim. The reference above was for a CS not an S nor the keder insert.2019 Tab 320 CSS, 2019 Ranger TV, OH0
Try using interior cable TV wire in the Kedar rail in lieu of the vinyl insert. A 75' roll will do a T@B 400 and it looks great!0
This is the same 1/2in plastic material along the edges of your CS. On eTrailer.com, it is called Premium RV Vinyl Insert Trim Molding - 25' - Black - 37210015.
I just replaced all of mine last week. It does look better with new material.
I was hoping to find an LED light cable the right size but never did.2018 320CS-S
"Just Enough"0 -
We took ours out and threw it in the trash.😂 it didn't match the cute aesthetic of our trailer. Are we supposed to keep it? It definitely got in the way when I was trying to put up my party lights and sunshade. There's no way I would be taking it off and putting it on and taking it off and putting it on. 5 1/2 years with no issues.2019 Custom T@B 320 U Boondock Lite-ish
We've slept in 34 states, 2 countries & counting0 -
When camping, we live behind the 'CS and not along side. We don't use the keder rail. With your regular 320, you probably live on the side of your trailer. No worries, we each use our trailers differently. If I was using the keder rail, I would trash the filler too.2018 320CS-S
"Just Enough"1
