Adding a portable solar panel/w controller, can I spice the output to the MPPT battery cables.
I am adding a Renogy 100 watt panel with 20a controller to my 2023 400 with 1 100ah lithium battery. Based on other posts and manuals, the solar panel output should be connected to the +/- distribution block.  The Victron MPPT 75 15 solar controller battery output goes to the distribution block.  Can I connect the Renogy output to those wires or do I need to run separate wiring to the distribution block.  I am putting the SAE connection in the Nautilus, so using existing wiring would be shorter.
2017 T@B 320 Outback 2023 400 BD (IdahoTabato) pushing a 2023 Volvo XC90
  • elbolillo
    elbolillo Member Posts: 575
    You will want to run separate wiring to the distribution block
  • Denny16
    Denny16 Member Posts: 5,430
    The Victron solar controller wires are gauged to only handle the output from the MPPT unit.  You need to run a second cable as elbolillo pointed out.  Trying to use the existing MPPT wire connection to the battery distribution block could overload those wires snd cause a fire.
  • Horigan
    Horigan Member Posts: 926
    edited July 2023
    With all those connections to the distribution block, you should consider switching to busbars.  Be sure to add a cover for the positive bar.
    Rich
    2019 T@b 400
    Bellingham WA
  • DaveC
    DaveC Member Posts: 83
    @Horigan, good suggestion. Looks like quality varies (at least on Amazon) do you have a brand recommendation?  Thanks.
  • SLJ
    SLJ Member Posts: 668
    edited July 2023
    I used these. They come with covers: https://amzn.to/3XMyb0x
    2021 T@B 320 S Boondock
    2025 KZ Sportsmen 130RD
    2025 Ford Ranger
    The Finger Lakes of New York
  • Horigan
    edited July 2023
    I like Blue Sea.  Be sure to get the power busbar (like my picture) with the larger studs for battery cables, not just a busbar.  SLJ's look good also.
    Rich
    2019 T@b 400
    Bellingham WA
  • bergger
    If you have a controller on your panel you can also just attach the wires directly to the battery terminals and skip installing another bus bar.
    2021 T@b 400 BD  "Vixen Gail"
  • DaveC
    @SLJ, thanks. are 5/16th studs large enough for the 10 gauge battery wires?
  • SLJ
    I used the 3/8 which was fine for everything down to my 4 gauge battery connections. The buss bars I used also have smaller #8 screw connections for things like my Victron battery monitor so I don't have to try to fit small wires on a main post with the battery connections.
    2025 Ford Ranger
