Yesterday when I returned to my camper from work, all the 110AC power was out. No Air Conditioner and no 110AC outlets. Since I am living full time in my T@B, this is an urgent situation. The campground checked their power supply and reported all good. I tested the power cable to the camper and all is good. All circuit breakers and fuses are good. No obvious issues are visible with the inverter. PLEASE advise what to check next.
Stancil Campbell
2011 T@B
Rockingham, NC
0 ·
Ken / 2023 Tab 400 “La Bolita” (20,000+ miles) / 2021 Honda Pilot
2024 - 1 Trip - 20 nights - 3 National Parks, 2 National Forests
2011 T@B
Rockingham, NC
2011 T@B
Rockingham, NC
You also mention an inverter. That would not have been a factory option back in the day. Do you have an inverter with automatic transfer switch installed ?
2011 T@B
Rockingham, NC
You mentioned inverter in your orignal post (inverters convert 12V to 110V). If you meant converter , here is a video that goes through a complete teardown and testing. If you have power on the camper end of your power cord , but none at the busbar, it seems like it has to be in the converter/power center or the wire between the camper plug and the power center. What model power center do you have? The video may provide some insight how to test your converter/power center (if its a WFCO) to confirm it's working ok. WFCO Power Source Training - Bing video RVTI WFCO Training - Bing video Good luck.
Southern Maryland
2011 T@B
Rockingham, NC
2011 T@B
Rockingham, NC
In terms of future prevention, I will definitely add dielectric grease between the parts, and will see if I can find someone who will weld those aluminum parts together for me.
2011 T@B
Rockingham, NC
Thanks for sharing.
