Thermostat
Does anyone have a suggestion for a replacement thermostat in my 2011 T@B? Here's a pic of the old one. Needs to control only the AC/Heat Pump. I no longer have a furnace. Prefer a digital type that does not break the bank.
Stancil Campbell
2011 T@B
Rockingham, NC
  • manyman297manyman297 Member Posts: 1,432
    I believe the one below is what newer units have. It works well and is fairly basic. I would double check to make sure you have the right wiring:
    Dometic CT Single Zone Wall Thermostat - Programmable AC Control w/Digital Temperature Display- Easy Wall Mount Design for RVs and Trailers https://a.co/d/7ZtyeLk
    2021 400 BD
    2020 Tacoma TRD Off-Road
  • EstancioEstancio Member Posts: 243
    FYI, Dometic says the thermostat for my AC is no longer available. While Dometic says I can use their upgraded digital thermostat, it will require a replacement of the control board for the AC unit. It appears to be a complicated process. Though others should be aware!
    Stancil Campbell
    2011 T@B
    Rockingham, NC
