Replacing Jensen Television
Resa_tab
Resa_tab Member Posts: 7
edited July 2023 in Modifications & Upgrades
Has anyone replaced their existing Jensen tv with another, non rv brand. I have a 2022 tab 400 bd.  I am looking at a 32” smart (fire) insignia (Best Buy) tv that has three HDMI ports.   Big questions are max weight on the wall mount, non 12v system (I think this is a big proven), and compatibility with Jensen sound system. Thanks!
  • Resa_tab
    edited July 2023
    Weight is 11.2 lbs
  • AnOldUR
    AnOldUR Member Posts: 1,757
    edited July 2023
    Replaced the Jensen TV with a Samsung 27" monitor. It's not heavy, but I replaced the mount with something more rigid. We use it to stream from a Fire Stick, iPhone or DVD player through the HDMI port. The 27" take up the wall behind the bath. I would think that anything bigger would stick out.
    edit: Should have noticed that this is for a 400 (not a 320), so not very relevant to you.
  • gulfarea
    gulfarea Member Posts: 524
    You also want a 12 volt one as I live in a hurricane area on the coast would not be without a 12 volt one. Art
    2019 TaB 320 S Boondock Edge
  • AnOldUR
    My Samsung came with a 14V power supply, but operates fine wired directly to the T@B's LiFePO4 batteries.
  • SLJ
    SLJ Member Posts: 659
    I put two Samsungs in my motorhome that ran on 12 volts. Look for the ones with the power brick on the cord. The back of the TV where the power cord plugs in should say 14V but they ran fine on the 12 volt RV battery system.
    2021 T@B 320 S Boondock
    2025 KZ Sportsmen 130RD
    2025 Ford Ranger
    The Finger Lakes of New York
  • Resa_tab
    Thanks. I’m glad there are options.
  • Marceline
    Marceline Member Posts: 1,770
    Interesting. And people might also want to note that these days it’s easier find monitors under 42” than TVs, if you don’t need the tuner.
  • Capthavoc
    Capthavoc Member Posts: 20
    Just put in 24 inch LG smart tv, fits in same space.  19 volt d/c from brick but cheap d/c booster runs it well.  Used the optical input adapted to rca for dvd from Jensen.  Bluetooth sound to Jensen works well.
