Just took delivery of our 2022 T@B 320S Boondock. Previous owner, I suspect, overtightened the Lagun handles and three of the four were bound tight. I managed to get them free with some WD-40 and time. Got the handles off and can see where the (carriage?) bolt threads have been damaged. Lagun sells the handles w/bolts for $30 per set (I need three of them). Seems to me I could replace the carriage bolts locally. Anyone have experience doing just that? What size bolts did you end up getting? Lagun replacement instructions call for a block of wood inserted into the leg and or table handle to prevent collapsing the aluminum "tube". Also calls for cutting out the old bolts with a hack saw. But you tap the new ones into place.
Thoughts/guidance?
Thanks
GaryP
