Mattress’s
Jetman
Member Posts: 45
Am wanting to purchase a new mattress for my 2018 TAB 400 with blue star Froli system and adding the red pressure clips to make the Froli more firm. Does anyone have suggestions about what mattress that have, use, and like very much.
Thanks in advance’
Thanks in advance’
Check this discussion out: https://tab-rv.vanillacommunity.com/discussion/16853/tab-400-mattress-topper-or-replacement#Comment_197245
--Marlee
2021 Tab400 Boondock; TV 2025 Jeep Grand Cherokee Limited; Minnesota0 -
Yes check out that discussion. We are still loving our Exped, placed on top of the factory mattresses which are still on top of the froli system. Having this set up also makes it much easier to remove the mattresses if needed, vs trying to get out a single much thicker mattress. And you can adjust the firmness of the Exped.2021 T@b 400 BD "Vixen Gail"
Leadville Colorado2 -
I suggest you buy new foam from sailrite. I used the firm and now have replaced all of the flimsy foam in our trailer, you can get any firmness you want. Less stuff is always better0
I put a 3” egg crate on my 400 and is now more comfortable than home0
