Glass Stove Top
2021 320 B just had the glass stove top explode. Decided to use something different as shown below. This is rolled up if using the stove, window open and screens retracted. Also have small fan to keep heat away from walls. Works fine so far
  • Yoshi_TAB
    Yoshi_TAB Member Posts: 597
    edited July 2023
    Hi,
    Glad no one was hurt.  Looks like a good solution.
    I also saw somewhere recently where someone had a thin aluminum plate cut to the dimensions and hinged at the back.
    The glass looks nice, but seems so fragile in the applied environment.
    Just curious, so I and others can learn..what was being done when the glass shattered?
    2025 360 CS
    Southern Maryland
  • DaveAnna
    DaveAnna Member Posts: 69
    Well, my wife put the glass down and forgot the burner. It was exciting at 5 am. From day one, I knew glass in a camper is a bad idea. Opening the small cabinet above was scary in case something fell out. I had planned on replacing with a pizza type pan that has an air gap. But this should work. We cook outside, this was her morning coffee…..
  • rfuss928
    rfuss928 Member Posts: 1,197
    The manual for this stove shows this same stove model with a metal top version. Possibly a replacement part is available?
    These people have always been very helpful to me:
    customersupportcenter@dometic.com
  • DaveAnna
    I emailed them. Let y’all know what they say
  • DaveAnna
    $75 incl shipping. I’ll stick with roll up for now. Will get back and plasma cut one out
