@crowsnest; Which make and model Fridge does your 400 have installed. Believe you own a 2018 400 which had two different Fridge options.
Most Fridge model Parts Lists are available on-line with many replacement parts available from different web-sites. For example here is a typical Norcold Thermostat; NR740/NR751
'18 320 S, pitched axle, 3020HE; PNW based TV: '17 Colorado V6 Z71 4x4, Tow Package, GM Brake Controller Adventures: 56Nights: 379 Towing Miles 47,220
I found that shining a flashlight on the AC screen (day or night) allows me to read it. The problem is that I'm short--my taller husband can read it without a problem. I keep a little flashlight on a hook under the screen just for that purpose. The other fix for me is using a small folding step stool. The screen is at an odd angle for short people and it looks blank.
I really dislike the Dometic thermostat. I have the same problem and can't see the LCD output. I would like to replace mine too. I'm not sure, but wouldn't any thermostat with a/c and heat pump option work? Having to use a flashlight does work but isn't ideal, now is it!
@GrayGhost do you have the sku or model number. I recall seeing the bluetooth version but with another part that goes near the Coolcat. I want only the bluetooth wall item.
2019 T@B400 TV: 2017 Nissan Frontier SV 4X4 Southern California Full-timer since 2019
The part is from Dometic. The part number is D7E 3316255000 BT CT
T-STAT - COOL/FURNAC. I bought it at my local RV repair center,
Richard's RV repair in Greer SC. I paid $112.39. The Dometic was an
easy direct replacement. Just remember which wire goes in which slot.
I recently saw this one Micro_Air EasyTouch RV Thermostat model
number. RV 351. Part Number: ASY-351-X02. They have a black and white
version. I l have not heard anything about this one, but it sounds good.
NR740/NR751
@crowsnest mine isn't small print...it's not very bright so sometimes seeing it is difficult for me. Maybe check with Dometic?
Dometic CT Single Zone Thermostat
Southern California
