I have a 2019 T@B 320s and recently had to remove the plastic underpayment under the tanks. Was wondering about the impact of adding Rockwool insulation to this space before re-assembling. The goal would be a warmer floor, not protecting the tanks against freezing.
Thoughts?
Ontario, Canada
2018 Tab 400
Ford F150 2.7 Lariat
2020 Tacoma TRD Off-Road
TV is 2007 Kia Sorento EX with 3.8L engine
For most of us the area of the floor to keep warmer is that small space from the Door to the rear bench seat. Well directly under nearly all of that area are the Gray and Fresh water tanks . . . so there is no way to get insulation in contact with the underside of the floor.
I find a small Rug works great for having a warm (enough) floor when waking in the morning. And far easier to install than additional insulation.
@tybladesmith do you know what the dimensions are of this insulation board? I guess basically I'm asking the dimensions of the corrugated cover since if I understand this correctly, this is under the cover, correct? I haven't gone to my trailer storage yet but wanted to see if it might be better for me to order some rolled foam/foil insulation from Amazon vs the board. TIA
