2022 T@B400 BD Lithium/Solar/DC/Starlink/CerboGX Upgrade
schwartzki
Member Posts: 51
Have a upcoming 6week trip this summer out west where we are planning on living and working off grid. This required some upgrades to the Tab. Went fully DC to cut inverter losses.
Installed a 50A DC sub-panel with dedicated fuse and shutoff:
2 DC power ports under the dinette along with a high-power USBC/USBA port.
WiFi Router for Starlink
12V->48V + POE injector for Starlink
Cerbo GX with Touch50 display for monitoring
I 3D printed a new touch panel to replace the stock NuCamp one. Added dimmers for the Accent and Sink lighting
Dedicated 100/50 MPPT for the exterior 600W of Solar
230ah of Lithium - camping in generally full sun so shouldn't need a lot of backup.
The Cerbo supports Bluetooth tank level monitors so LPG, Fresh and Grey will have Bluetooth level sensors.
Have interior temp/humidity monitoring via Victron Remote Monitoring.
Walker Tent is on order to double SQ FT and likely where the dogs will spend most of their time.
2022 T@B 400 Boondock (~21,000 miles) as of 10/07/25
2022 - 11 trips - 34 nights
2023 - 4 trips - 21 nights
2024 - 5 trips - 51 nights
2025 - 5 trips - 18 nights
2024 Ford Ranger Raptor (10.5 mpg towing avg)
2018 BMW X5 xDrive35diesel (15.6 mpg towing avg)
2020 Toyota Tacoma TRD Off Road (11.1 mpg towing avg)
2
Looks great! We’re upgrading to lithium in our 320S and thinking of putting in the Cerbo GX too. Thanks for sharing your custom printed panel… now we have ideas so we can ultimately ditch the NuCamp panel.2023 T@B 320 S Boondock
2011 Toyota Tacoma 4WD + tow package
Longmont Colorado0 -
@schwartzki did you use the Mopeka BT tank sensors or something else?2023 T@B 320 S Boondock
djaiko said:@schwartzki did you use the Mopeka BT tank sensors or something else?
Yes, the Mopeka tank sensors. Not installed on the black tank however. Still have the old touch panel above the door connected for backup.
2020 Toyota Tacoma TRD Off Road (11.1 mpg towing avg)0 -
Good to know. Was it easy to get at the bottom of the fresh and grey water tanks to install them? I guess the tank access might be different on our 320S but just curious.schwartzki said:djaiko said:@schwartzki did you use the Mopeka BT tank sensors or something else?
Yes, the Mopeka tank sensors. Not installed on the black tank however. Still have the old touch panel above the door connected for backup.2023 T@B 320 S Boondock
It was pretty easy. Just take down the left side undercover and slap them on.
We have a 2022 T@B 400 also that we are doing a solar upgrade with a Cerbo GX, would you be open to sharing the STL file for the panel you printed ? Also with the light dimmers did you notice any flickering ? Which dimmers did you use ?
enzo86 said:I 3D printed a new touch panel to replace the stock NuCamp one. Added dimmers for the Accent and Sink lighting
No flickering on the dimmers most of the time. Link to dimmers here. I will see if I can get the STL file to share with you via DM.
PWM dimmers!! Why can't I think of simple mods like that...great idea. Thanks!schwartzki said:I 3D printed a new touch panel to replace the stock NuCamp one. Added dimmers for the Accent and Sink lighting
I put one in my fan and love it.73 es God Bless de KK1L, Ron <><
Jericho, VT0
