Hello, has anyone seen any issues with the metal support brackets that hold the underside cover?
I was crawling under my 2022 T@B320S and found several screws holding the large sheet of protective undercover to be broken. I've only used the trailer for one summer so far so this is concerning as if it comes off while I'm driving it could puncture one of my tires or get loose and hit cars behind me.
Has anyone else noticed this?
I think I need to drill the old screws out and put new screws in but the question is how long are these screws? I guess I will have to remove an existing one out to find out. Weird...
2025 KZ Sportsmen 130RD
2025 Ford Ranger
The Finger Lakes of New York
2021 Toyota RAV4 TRD Off Road
Ottawa, Ontario, Canada
Instagram: new.t@bventure
2025 Ford Ranger
Thank you for being a part of the nuCamp family.
They either need to train their people on how to use an impact driver properly or switch to a clutched drill. These campers have stripped out or overly-driven screws everywhere and it’s leading to a plethora of issues. I found so many stripped out screws in the interior cabinetry.
2020 Tacoma TRD Off-Road
You will want to use a self tapping #8x 1" screw. You can just put them in next to where the other screws broke off.
If you have any other questions please let us know.
2025 Ford Ranger
Yes the Coloplast scrim was installed with ferrous not stainless self tappers. Nucamp setting gapped crooked heads, overdriving, and not predrilling, mean a large number were sheared off or stripped when I had to remove them for maintenance work.
Rather than woodpecker the very thin structural C channels with more holes I backed or drilled out failures and replaced all with ss no.12 hex/washer head sheetmetal screws, predrilled.
No cabinetry screws were predrilled, causing widespread splitting and veneer failures. Sink overhead cab doors fell on our heads as they did not drill and fully seat short hinge screws.
Circuit breaker screw terminals were overtorqued with gun and stripped, some not reusable and one loosely jiggling 120v feeder.
Were this a building I could cite ICBO fastener codes and fail them all. A contractor would be in serious legal jeopardy for such poor workmanship.
