J.D. & Sue
I used some other formula I found on the web and it appears to be about 2ah. I think a solution could be to add a small solar panel to the mix.DurangoTaB said:My guess is it ain't much...like 2-3 amps, similar to a trickle charger.
I'd be curious to know what formula/calculator you use to compute TV output current? It's based on power requirements so it would be interesting to understand their methodology.jkjenn said:I used some other formula I found on the web and it appears to be about 2ah. I think a solution could be to add a small solar panel to the mix.DurangoTaB said:My guess is it ain't much...like 2-3 amps, similar to a trickle charger.
I am impressed.T@Buhura said:I'd be curious to know what formula/calculator you use to compute TV output current? It's based on power requirements so it would be interesting to understand their methodology.jkjenn said:I used some other formula I found on the web and it appears to be about 2ah. I think a solution could be to add a small solar panel to the mix.DurangoTaB said:My guess is it ain't much...like 2-3 amps, similar to a trickle charger.
Since I had been wondering the same thing and what I did was put my multimeter in series between the XC90 and the T@B using patch cables with alligator clips on the pin that provides power to the trailer to get a true measure under load.
The XC90 puts out nearly 7A which is great for offsetting a little more than half of the fridge's 13A on 12v while towing.
| see what the fuse size is protecting |
Wow! Yeah, I wouldn't go by that logic at all. All he's really calculating is the amount of power the fuse can support and then applying an arbitrary engineering margin (unless he knows for sure). Even if it is a known margin for the JK it's still a broad range which the circuit could support.jkjenn said:I am impressed.
I have no idea where he got his formula from or if it is even right, but I found this on a Jeep forum:
"I then converted watts to amps and accounted for an 20% loss. Probably horrible logic, but I am not going to buy one of those tools right now to measure.
see what the fuse size is protecting the circuit the trailer connector is on and multiply it by 13.2. If it is a 20 amp fuse x 13.2 volts = 26.4 watts then figure you are good for 80% which is around 21.12 watts.
Thanks, @ChanW. I would assume that the this won't translate to what is actually at the 7 pin connector, but it dies help me understand better. I have wondered if it would help me to disconnect my winch from the battery when not in use.ChanW said:Not sure this is going to help you with your calculations, but this article is pretty good at describing TV alternator output (clearly better than me! Note a typical automotive alternator is rated at 80A)
http://cartech.about.com/od/Power/fl/Understanding-Alternator-Output-Ratings.htm
Funny, this has been on my wish list for a couple of weeks, Let me knw how it works!ChanW said:Unless the winch switch is faulty, it should not be drawing any power if you aren't using it, so there's no need to disconnect it.
I'd be sure to disconnect the Tab before you use the winch though! Or at least turn off the fridge...
You got me wondering, with this thread, so I ordered a simple 12v watt/hour amp/hour meter, which's designed for these types of measurements (RV, solar, RC models, etc.)
It's called 'Watts Up'.
There's a cheap one on Amazon, and a more expensive one too, with the same capabilities. Looks like the cheaper one is less reliable, from the reviews. The better one comes highly recommended from those who know those things.
It'll measure your amps, watts, voltage, as well as accumulated consumption over a period of time, ie: amp/hours and watt/hours.
It would have to be installed in-line wherever you're trying to measure, like between the TV and the Tab, or between your solar panel and the Tab, etc.
The cheap one: http://www.amazon.com/Digital-Battery-Balance-Voltage-Analyzer/dp/B00EYZS6R6
The better one: http://www.amazon.com/Watts-Meter-Analyzer-WU100-Version/dp/B001B6N2WK
I'll let you know what I learn (if I learn anything B-)
@ChanWdid you ever get that installed?ChanW said:Unless the winch switch is faulty, it should not be drawing any power if you aren't using it, so there's no need to disconnect it.
