Leak 2017 T@b 320S Underneath Passenger Side
CEdwards
Member Posts: 2
Hoping someone could point us in the right direction. Discovered a leak this spring. Re-caulked tail light, but that wasn't it. Small leak at brass fitting, tightened screw in pic (thanks to this forum!). No more drip, but that wasn't the issue. It seems to be when pump is on. Underneath passenger wheel very soggy. Any words of wisdom? We will take it to repair shop, but hoping we might be wiser when we do. Thanks so much.
On the passenger side, have you checked the caulked areas in the wheel wells?
https://tab-rv.vanillacommunity.com/discussion/6393/maintenance-notices
Thanks, but it's not water coming in..it's water coming.out of the camper. Although is also something to check amd maintain for sure!
