Getting ready to dry camp for 4 or 5 days. I got a sae pigtail for my solar panel controller, and my charger for my gen has a sae adaptor. Both of them needed the polarity reversed to plug into the tub on my 2021 320s. is this normal? Should I be concerned? obviously an electric novice. Thanks.
0 ·
2025 KZ Sportsmen 130RD
2023 Ford Maverick XLT
The Finger Lakes of New York
The positive wire from solar panels or any "external" (not connected to the trailer) power source is not a source of spark or shock unless that source's ground is also connected. Think of it like your holding any standard dry cell battery. Either end can touch any part of your trailer and nothing will happen. Both poles of the source need to be connected to complete the circuit. Mechanics learn to connect the positive side of the battery first so there is no spark danger if your wrench bumps any of the grounded metal all around. Then you connect the battery ground to the vehicle with only the positive terminal to worry about.
The point is: There is no concern wiring your solar with the positive on the exposed SAE male pin. This will mate with typical vehicle battery SAE connections with the positive on the covered female terminal so it can't bump anything grounded on the vehicle.
