Isotherm Cruise 65 on the way…Advice welcomed!
rudacille1
Member Posts: 6
Watching what has been shared on this forum gave me (the false?) confidence that I could change out my 3 way fridge (T@B 320s). Counting on your support. Planning to center the new unit and fill in with maple. I think that is my entire plan until I begin the destruction, I mean construction.
Welcome @rudacille1 and good luck! You found the right help!Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
Congratulations. Mine works great. Very efficient. I never have to worry about the fridge having enough power.2021 T@B 320 S Boondock
2025 KZ Sportsmen 130RD
2025 Ford Ranger
Good to hear. Did you do the instillation yourself?0
Unit has arrived. Sawzall and crowbar ready. Any advice in how to remove the 3way Norcold?0
@rudacille1 Did you get the unit in? I'm going to get an estimate for an install. If you search "Isotherm Cruise 65", you will see @RON did an install on his own, but he did not comment on how he removed the original unit. How did you remove your old unit. Thank you.2017 T@B 320 Q Max
2018 Toyota Highlander, XLE
Wisconsin0
- 920 Introductions
- 75 Teardrop Groups & Links
- 916 Tips & Tricks
