On a recent trip in our newly acquired 2019 T@B 400, we could not get the Alde heater to work. We did get hot water, but no heat. I think the problem may be with the indoor temperature sensor. On the standby screen it shows the temperature to be 158 F. Clearly it was not over 60 F inside. Understand that the heat will not come on until the indoor temp is below the setting, which is 72 F. Have tried resetting the system and rebooting by removing shore power and turning off the battery. When starting system back up it still says indoor temp is 158 F. Have not figured out where the sensor is located. Any thoughts on this?
0 ·
1, Review each of the menu screen items with manual handy . . . is something set to an odd condition "like timed operation" or circulation pump always off.
2. If nothing jumps out as the issue; consider using the Service Menu to reset the unit to Alde Factory conditions (I'm not sure but do suspect that's nuCamp's factory settings.)
If you have Hot Water the Adle is working - - - you just need to find out why the 'cabin heating' circulation pump is not running.
Adventures: 51 Nights: 322 Towing Miles 41,200+
This is also used when flushing the glycol to force the pump to run, so you can see if it is working. As the indoor temp is only able to be changed via the offset function, not sure how to fix that, but if the glycol is heating and you have hot water, forcing the circulating pump on should give you heat.
See if that works
Edit: In the automotive world sensors show abnormal low temps when the circuit is open and abnormal high temps when the circuit is shorted. 158F indoor temp makes me think shorted sensor. Does the 400 have an external sensor ? I know my older 320 doesn't.
You can try messing with the temp offset as well. But it only offsets plus or minus 10 degrees F so not sure if that will help. But maybe adjusting that will trigger something to make it work?
The thermal sensor is just to the left of the spring. The sensor was touching before I moved it. We now think this could have happened when the controller was bumped and the cover came off. The cover was put back not knowing what it should look like, so had no idea that the sensor was being shorted out.
I'll follow up later to confirm this solved the problem. Thanks again everyone.
