Hi,
Just want to pass on some info. that may or may not be helpful for those moving over to Lithium batteries and are considering not changing out the non lithium charger /converter. I have two lithium batteries and did not change out the WFCO 8735P (stock for lead acid) in a 2021/320. I always read that the WFCO will not charge the lithium batteries to 100%. I have found that my WFCO 8735P does consistantly charge my two x 105 Ah lithium batteries back to 100%, every time although slow. This is measured with a shunt. But I have to “fake it” into charge mode by turning off and on both the battery switch and shore power at the same time. When that is done, it always starts the charger and takes the batteries to 100%, every time. If only one is turned off, it does not kick on the charger. Without turning both off/on, the charger will never go into charging mode I think because the voltage of a discharged lithium battery is still higher than a discharged lead acid battery and the WFCO does not detect a low enough voltage to go into charge mode. Here is the charging data I've seen on a multiple occasions. This is with the solar charger turned off. So, after boondocking and back home you may be able to get your lithium batteries back to 100% and you are not in a hurry. It maybe worth checking before changing out your equipment and slow charging works for you. I understand that solar and/or an external charger gets you to the same place…maybe faster. Just another option that may work for others. And occasionally charging with a lithium designed charger helps to balance the cells. Below is some data, but I’ve had the same success start at 60% SOC. The voltage was measured at the converter output on the WFCO (the vcc connection point). The 13.67 is at the resting stage.
Happy charging....
Time SOC (%) Current (A) Voltage (V)
T0 80 0 13.27
T 1 hr 15 min. 83 5.85 13.49
T 2 hr 85 6.26 13.50
T 4 hr 30 min 92 6.00 13.51
T 5 hr 30 min 94 5.82 13.51
T 6 hr 30 min. 97 5.14 13.51
T7 hr 30 min. 99 4.43 13.53
T 7 hr 45 min 100 4.34 13.55
T 8 hr 100 2.91 13.58
T 8 hr 15 min 100 0 13.67
2025 360 CS
Southern Maryland
1 ·
Update;
GM ; After 24 hrs with battery switch off (and solar off) it remained at 13.68
I believe it does, but I will double check. Just posted to let others know it may work for them. I know the WFCOs can be finicky. My WFCO will never start a charging cycle (for the lithiums) no matter how low the SOC is. It worked fine for LA. I’ve emailed WFCO but never get a direct answer (other than to switch out chargers which I do not plan to do) to as why it won’t start a charge cycle …as I said I’m guessing because the lithium does not get below the threshold voltage to kick on the charger.
Southern Maryland
2025 KZ Sportsmen 130RD
2025 Ford Ranger
The Finger Lakes of New York
Sold 2023 Tab 400
Sold 2018 T@B 320S
Understood…Tks Buried in my original post I mentioned that. I have a lithium charger…I just posted some results I stumbled on ..for some reason my WFCO will charge the batteries to 100% where I never see that mentioned, always just 80-85 percent or there abouts…happy charging.
Southern Maryland
Sold 2023 Tab 400
Sold 2018 T@B 320S
Southern Maryland
