Battery was at 100% at 3p in afternoon when I disconnect my tow vehicle. With nothing on but the fridge on propane, battery was at 42% at 7P the following day (28 hrs later). Outside temps in the 50s-50s. Is this normal with a one-year old battery?
0 ·
In general what you are reporting is abnormal.
If a typical 320S draws 500mA (0.5 A) per hour - - - which is high compared to the real world typical.
Your battery would have been drained some 14 Amp-Hours . . . 14% if the battery is a 100-AHr [20% if a 70-AHr dealer basic was installed]. . . not 42%
So first reaction would be:
== A == You have more 12VDC 'things' turned-on then you realize
== B == How you are measuring the power loss/capacity is wrong. For example the KIB Tank Monitor
Battery LED Lights are worthless.
In terms of things left on, it’s just the stereo display light, smoke and CO detector, and fridge light. I have a master kill switch at the battery but it seemed to turn off the fridge (running on propane but indicator light obviously needs power). I wonder if you can run the fridge on propane with battery disconnected.
Thanks!
You might consider getting a cheap clamp style Current Meter.
Clamp it to the Battery Negative terminal wire,
then you can measure the current with various combination of trailer 12VDC items turned-on or off.
Here is a $30 meter
A cheap price clamp on meter will be more than accurate enough for this project.
