I couldn't find the answer in a previous discussion, so I'm turning to all of you once again.
Everything works fine when we're plugged into shore power, but nothing works when running only on battery.
My husband has checked all the fuses on the battery and inside the Tab. Our lead acid battery is fully charged.
We have a Victron shunt, and that's all doing fine per the app. We do have the battery knob in the propane tank box turned to green.
The factory-installed Victron unit for the solar panel under the driver's side bench hasn't been working all summer, meaning it's not detectable by the app.
Any thoughts? We're heading out camping in five days and would like to get this sorted out.
Thank you so much!
0 ·
Hi,
The below sketch shows how it's wired if your unfamiliar. The 12V power from your battery goes thorugh a 30 amp fuse, through the ON/OFF switch , to a junction box located under the trailer frame. From the junction box, the wire goes into your TAB directly to the WFCO power center. The WFCO power center distributes the 12V power to the fuse block on the right side of the WFCO to the individual 12V circuits for each 12V appliance in your TAB. The solar is a seperate circuit and I'd put that to the side for now until you sort out the 12V issue.
I would suggest:
1. Confirm with a voltmeter (hopefully you have one) your battery is fully charged. You should have 12.6V or there about.
2. Confirm all your connections on your battery are tight.
3. Confirm the battery fuse (in the tub) is not burned out. Sometimes they are hard to see if burned out. I would check the fuse with a meter using the continuity setting. I would check the power across the fuse to confirm you have 12V. If your not sure how to do this...please ask. This will check everything up to the fuse.
It's hard to check anything else until inside the TAB at the WFCO. You can check the junction box if you suspect a bad wire connection there. It is the #6 stud. You take cover off. But I'd hold off on that for now.
4. Confirm the bottom two fuses in the WFCO are good by checking continuity.
5. Confirm you have 12V in the WFCO. If you open the WFCO cover and remove one of the fuses and use a meter to check for 12V across the open fuse. You should have 12V.
Hope this helps as a start....Ask if anything is unclear.
Southern Maryland
Best method (with all power off) is to remove and check with an ohm meter.
What you describe sounds like a possible Reverse Battery or Solar Panel wiring error.
Suggest you:
= a = Confirm in-line fuse at battery are on wires connected to the battery Positive Terminal
= b = Confirm the Power Center two bottom fuses 30A & 40A are good.
These two connect to battery and detect battery is installed correctly.
= c = If 'a' and 'b' are correct/okay, consider removing the Solar Controller Battery connections
2025 KZ Sportsmen 130RD
2023 Ford Maverick XLT
The Finger Lakes of New York
I found my error using a multimeter to check connections starting at the battery.
2023 T@B 320 S Boondock
Southern Maryland
