Need Replacement for Broken T@b Boondock Cargo Bin Latch Handle
Does anyone know of a replacement for the rubber handle that is used to latch the T@b Boondock tongue storage bin? One of mine broke in two when I pulled on it last week.  There are several on Amazon, but they all come in different sizes.
My dealer said they would have to order it from NuCamp.  I was hoping to fine one online.  If I can find the same size handle, I won't have to replace the other parts.
Thanks.
NuCamp Part Number 66-00-4791
(Picture is of the other, so far, intact handle)
2021 T@b 320 S Boondock
2020 F150 2.7l V6 Turbo
Tucson, Arizona
  • SLJ
    SLJ
    edited October 2023
    They are called T Handle draw latches. Several on Amazon. You will have to measure yours to match it up. https://amzn.to/48OagTt
    2021 T@B 320 S Boondock
    2025 KZ Sportsmen 130RD
    2025 Ford Ranger
    The Finger Lakes of New York
  • Thanks SLJ.  I already looked there and it is hard to find any dimensions.  I will look some more.
    I was hoping that someone on the forum has already done this.  This must be a common problem.
    Tucson, Arizona
  • SLJ
    SLJ
    edited October 2023
    The one I linked to above shows the size (2.76") and matches the ones used on my 2021 tub. You will need to measure the length of yours as there could have been different suppliers. The 2.76 is the critical length.
    2025 Ford Ranger
  • @SLJ That looks like a good fit.  Thanks
    Tucson, Arizona
  • Hi all. I found some draw latches that worked. These were a similar size to the original ones, so I tired these instead of the ones that SLJ recommended.  There was one problem with them, they had a piece of rubber on the pivoting end that I had to saw off.  Once I cut that off it worked.  (Luckly I bought two since my first attempt on trimming did not look so good.) Their length and diameter of the ball fit fine.
    Here is what I purchased. They may be better fits out there:
    Below are more pictures of the latches, with the old broken one next to the new one.
    The new latch installed:
    Hope this helps someone.
    KH
    Tucson, Arizona
  • These worked fine too,  replaced mine in 2019 and it still looks good, held up better than the one it came with.
    https://www.amazon.com/gp/product/B07CQK96Q2/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
