Had a few questions we were hoping to get some perspective on:
1. The data plate on the Isotherm 65 fridge says it runs on 12vdc and/or 120vac.  Anyone know what conditions are necessary for it to operate on 120vac? We're completely fine running it just on 12vdc, however, just curious.
2. There's two open cavities in the rear of our 320.  One is behind the Air8 a/c unit, the other is behind the Alde 3020 system. Both areas look like ideal storage locations. Can the paneling underneath safely sustain much weight?  Say, 40-50 lbs?
3. Just finished fabricating a generator cover for the A-frame and along with a number of electrical upgrades.  Last project before we seriously hit the road is a bike rack.  Would prefer not to increase our tongue weight with an A-frame mounted bike rack.  Anyone carrying their bikes on the 320 rear roof rack?  That upper bar on the roof rack is up there pretty high. Anyone loading/unloading their roof rack mounted bikes without the need for vertical assistance?
Thanks!
1, The Isotherm is only 12V. When on shore power the converter provides the 12V to power it. There is only a12V fuse for it, no breaker. Be aware when running on battery, the fridge will not operate if the voltage of the battery gets below around 11 or so. One mod many do is switch the side the door swings open with the hidge on the left. Makes getting things much easier when standing outside at the door.
Manuale Drawer 2013 (indelwebastomarine.com)
2. IMO, that area can sustain 40-50 lbs. Another mod is to change the hinge so the cushions flip up at the front. Makes getting items way easier. The mod still maintains the ability for the seat to ratchet as a seat back.
3. It is not advise to put bikes on the rear rack. It is rated for only (edited updated) 75 lbs. Although I believe some have. Many use a rack called a Jack It. The nice thing about the Jack it, it has an accessory called a bump it that allows you to remove part of the rack and put it on your tow vehicle to travel locally with your bikes when you have your camper.
Keep asking questions..
Happy Travels...
Southern Maryland
Appreciate you clarifying how the Isotherm operates (and the door mod). Got to wonder why Isotherm puts 100-240vac, 50-60 hz, 1.0a/.5a on the inside data sticker.
The cushion mod is awesome! Just put that mod on our to-do list.
Wasn't aware the load rating on the rear roof rack was so low (60 lbs). For those who used the roof rack to store their bikes, I'm guessing they probably needed ladders to access them.
Southern Maryland
2023 T@B 320 S Boondock
On our 2021 320 the rear tubular rack is attached through the camper skin to the very lightweight aluminum framing shell members with four throughbolts having plate washers, visible from inside. I would not put any loads on this rack out of concern of buckling or tearing through the composite shell.
I agree that rear, aluminum brush guard is a no-go. We're hoping to use the OEM steel tubular roof rack (Yakima?) located just above it. Trying to nail down the exact load rating for this particular roof rack. So far I've heard estimates from 60 to 125 lbs.
2025 KZ Sportsmen 130RD
2023 Ford Maverick XLT
The Finger Lakes of New York
I can't quite visualize how it would still allow for the ability to ratchet the seat. Thank you!
2021 Toyota RAV4 TRD Off Road
Ottawa, Ontario, Canada
Instagram: new.t@bventure
Here are a couple of close up pictures and video that might help.
The BOM was:
-Square door hinge
-Bar stock
-Small screws
-T-nuts
-Wood Screws
Tools: hacksaw, drill/bits, screw driver.
The OEM assembled seat has the front of the cushion screwed/attached directly to the ratcheting hinge so the cushion pivots on the ratcheting hinge. This modication moves the hinged point from the front of the cushion to the rear (using a door hinge) so it can swing open from the rear. It installs a piece of bar stock to attach the rear hinge to the front OEM ratchteing hinge.
There is a similar mod that welds the componets together. I used small screws and T-bolts to secure the parts together, so no welding was necessary. I also used locktite on the screws to keep them from backing out. I used wood screws to attach the bar stock to the bottom of the seat cushion. Works really well. If I wasn't clear...please ask.
Southern Maryland
I would add a false bottom to the rear storage modification. You need air movement for the Alde heater to work properly. Air needs to flow from the floor through the cabinets and through this back storage area up across the heating plates behind the rear storage cabinet.
We've been very pleased with the Jack-It bike rack. If you do not plan to install an electric tongue jack, go with the shorter frame option so the bikes are a little easier to reach.
2020 V6 Chevy Colorado
Good point about maintaining air movement for the Alde heater. We'll have to keep that in mind when we store anything back there.
I've heard good things about the Jack-It bike rack. Unfortunately, it would push our tongue weight a bit higher than we'd like. If our current R&D doesn't pan-out, the Jack-It will be a strong Plan B.
