Looking for assistance - I had battery disconnect switch in in the “on”position and lost power to my 2018 Tab 400 without realizing it. My two 200 aH Renogy LiFePo’s got real low - one is at 9 ah’s and the other is at 6 ah’s. Now when I try to charge them, the Gloso trips every time after 3 - 4 minutes. I’m trying to bring the battery up with my suitcase solar panel but I’m in Ohio and it’s almost November so that’s not going well. Has anyone seen this before? My converter is a WFCO 8955 LIS (the one with the switch).
I would appreciate any guidance!
thanks,
Steve
2025 KZ Sportsmen 130RD
2023 Ford Maverick XLT
The Finger Lakes of New York
temporarily disconnect one of the batteries charge up the other. Once one is topped off, reconnect the other. Perhaps the charger will not “try so hard” to deliver its full output, and avoid tripping the breaker.
While on the subject of losses and heat generation...the resistivity of the wire is distributed and therefore the power dissipation (heat...I-squared x R). Where it can be concentrated is at poor crimps, connections, or sharp kinks in the wiring. When adding or modifying pay attention to this.
Jericho, VT
Reviving this old thread on the undersize Gloso as my 360CS (June build) is suffering from the same issue.
The WFCO is putting out over 40 amps and the Gloso keeps tripping during a charge cycle. Our CS (non Lithium upgrade) did come with 4 AWG wiring, so upping the Gloso to 60 is no issue.
I'm going to e mail NuCamp support to see if they have an explaination of why they only put a 40 A breaker in.
Southern Maryland
