Tool for lowering stabilizer legs
PeterTAB
PeterTAB Member Posts: 19
edited November 2023 in Products and Accessories
Hi, I have a 2017 TAB 320 and it came with a wonderful hand crank thing for lowering the four stabilizer legs of the trailer. Alas I have forgotten it at home and am 6 hours away at a campground.
If I were to swing by a Walmart, what tool would I want to pick up to lower and raise the stabilizer legs? I tried a socket wrench with various size sockets and the don't work.
Thanks!
  • webers3
    webers3 Member Posts: 450
    You need one like that, maybe available at Walmart, make sure it's the slotted type like the one shown here: https://www.walmart.com/ip/BAL-21100003-Slotted-Cordless-Drill-Adapter-for-Stabilizing-Jacks/50313957?wmlspartner=wlpa&selectedSellerId=0
  • Maxcamp
    Maxcamp Member Posts: 352
    If this tool is not in stock, there are a couple of approaches that come to mind.
    1. Pick up a vice grips and wrap a bit of cloth under jaws to limit damage to leveler.
    2.  A lumber store would sell EMT conduit and hacksaw, slot each end to accept leveler and screwdriver shank as turning device.
    3.  We often forego levelers if sleeping hitched up to truck on enroute stays.
    Good luck.
  • PeterTAB
    Vice grips did the trick! Thanks folks!
  • Slackers
    Slackers Member Posts: 490
    FWIW, earlier this year we loaned a pair of Vice Grips to another camper in a situation similar to yours.
  • Its a 19mm bolt head. A 19mm socket will operate it. I have to use same in my driveway where I don't have room for the long handled doohickey that came with the camper.
    2023 T@B 320 CS-S | 2016 XC60 T6 3.0 AWD | PNW
  • ColleenD2
    ColleenD2 Member Posts: 583
    oh no! I have asked a neighbor to borrow theirs once.
  • Horigan
    Horigan Member Posts: 928
    The 19mm bolt head version came out later.  Our 2019 has it, but our 2016 had the version shown in the original post.
    Rich
    2019 T@b 400
    Bellingham WA
  • Mickerly
    Mickerly Member Posts: 518
    2018 320CS-S
    "Just Enough"
  • ColleenD2
    We bought this one but it’s not really tight enough to work well so we are still doing it manually. I will try the one @Mickerly bought. Is it a tight fit? We are a 320U 2019.
    https://www.amazon.com/gp/product/B07QRMPTYN/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
    @ColleenD2 - we use the Ultra-Fab, too.  It works well with our drill.
  • Mickerly
    We have a 2018 CS. If it is a little loose, set it on the driveway with the grove horizontal. Whack it once or twice with a hammer to tighten it up. Start softly in case it is mild iron.  ; )
    2018 320CS-S
    "Just Enough"
