I'm considering replacing our stock AGM batteries with lithiums. I need to know how big the battery box is, and before I go through the chore of opening that up I thought I'd ask and see if someone has that information on hand. If anyone also has thoughts on this they'd like to add that would be great as well. (I have been reading over discussions on this forum).
Thanks!
Bubbles - 2022 T@B 400 Boondock
Tug - 2021 F-150 4x4 Hybrid
0 ·
2020 Tacoma TRD Off-Road
https://battlebornbatteries.com/product/100ah-12v-gc2-lifepo4-deep-cycle-battery/
2019 T@B 400 BL
2021 Toyota Sequoia 4WD
relentlessly pursuing a
2025 Silverado EV
2018 T@B 320 Sold
Racing the Wind and Chasing the Sun
Virginia Beach, VA
If you don’t typically charge at up to 14.4V your cells may get a bit out of balance because of temperature extremes or larger loads. To rebalance your system, we recommend being able to charge it up to 14.4V once a month or even once a week. Please note that it depends on your system usage. You may not notice anything, but if the batteries are hitting high voltage disconnect sooner than you’d expect, for example at 14V, or if they’re hitting low voltage disconnect sooner than you’d expect, such as at 11.5V , then you may want to think about rebalancing the battery cells internally and all you must do is charge it up to 14.4V in order to rebalance the cells."
I am not an expert on batteries and charging, so I just have relied upon BB's site and their technicians to guide me with my setup. I haven't noticed any anomalies with my setup since installation.
