I have a new 2024 Tab 400 and am trying to winterize. The manual states to drain
"c. Hot water tank & FLOW drains. Yellow Alde drain valve. Vertical position is open...."
For the life of me I can't find this Yellow Drain Valve. Any help out there? Many thanks.
This nüCamp Video briefly shows the location of the primary, Boiler, Yellow Valve and also covers the how to set/use the Nautilus System while winterizing.
nüCamp Support Newer 400 Winterize
If your rig has a Alde Flow System Yellow Valve it will most likely be located near the Alde propane exhaust vent/piping as shown in this image
- - - compiled from different thread images - - -
** the Flow Tank/Unit is installed on the cold water line before the Alde Boiler, it is not a tank. It is a heat exchanger that uses the very hot water exiting the boiler to pre-heat the incoming cold water. That way the Boiler does not have to work as hard heating 'new' water to it's pre-set temperature. My 320S does not have a Flow Unit; my guess is that having a Flow Unit would extend the volume of hot/warm water and perhaps reduce the colder water shock when taking Navy Showers . . .
it is not intended to be a continuous hot water source like a house Hot Water Heater.
