Replacing the Filter Material on a Cool Cat
Mouseketab
Member Posts: 1,238
Well, today while I'm doing T@B chores this weekend, decided to clean the CoolCat filter.
Unfortunately, when I pulled it and started vacuuming it, it started disintegrating.
Has anyone replaced the filter material? I'm pretty sure I can find some at a home improvement place.
See the beading on the plastic piece. That was some type of adhesive used to attach the filter material. What do you supposed it is?
Or should I punt and just order another one from Pleasant Valley?
Carol
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL
MOUSE-KE-T@B
Harvest, AL
Punt for a call to Pleasant Valley. It's damaged enough, Carol, that you'll have too many gaps and won't be able to prevent the dust from entering the Cool Cat.Verna, Columbus, IN
I'm actually trying something first. I found a product at home depot with filter material with a plastic web backing, cut to fit. I cut it to fit and put it in. I had Googled Cool Cat filter, and it was $45!!!! What I found was less than $10 and I can get 3 filters out of it.Carol
MOUSE-KE-T@B
Harvest, AL -
Great! I'll need to find that because I already broke my filter removing it for the first time.Mouseketab said:I'm actually trying something first. I found a product at home depot with filter material with a plastic web backing, cut to fit. I cut it to fit and put it in. I had Googled Cool Cat filter, and it was $45!!!! What I found was less than $10 and I can get 3 filters out of it.Verna, Columbus, IN
Sandra, it was actually the water that did it in. I noticed some issues with the vacuum, so stopped that, and started running it under the sink, and it just fell apart.
Eight years old, things disintegrate.Carol
MOUSE-KE-T@B
Harvest, AL
- 916 Introductions
- 72 Teardrop Groups & Links
