Replacing the Filter Material on a Cool Cat
Well, today while I'm doing T@B chores this weekend, decided to clean the CoolCat filter.
Unfortunately, when I pulled it and started vacuuming it, it started disintegrating.
Has anyone replaced the filter material? I'm pretty sure I can find some at a home improvement place.
See the beading on the plastic piece. That was some type of adhesive used to attach the filter material. What do you supposed it is?
Or should I punt and just order another one from Pleasant Valley?
Carol
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL
  • Verna
    Verna Member Posts: 6,876
    Punt for a call to Pleasant Valley. It's damaged enough, Carol, that you'll have too many gaps and won't be able to prevent the dust from entering the Cool Cat.
  • Mouseketab
    Mouseketab Member Posts: 1,238
    I'm actually trying something first. I found a product at home depot with filter material with a plastic web backing, cut to fit. I cut it to fit and put it in. I had Googled Cool Cat filter, and it was $45!!!! What I found was less than $10 and I can get 3 filters out of it.
    Carol
    MOUSE-KE-T@B
    Harvest, AL
  • Verna
    Great! I'll need to find that because I already broke my filter removing it for the first time.
  • Mouseketab
    Sandra, it was actually the water that did it in. I noticed some issues with the vacuum, so stopped that, and started running it under the sink, and it just fell apart.
    Eight years old, things disintegrate.
    Carol
    MOUSE-KE-T@B
    Harvest, AL
