TAB 400 2021 Tires
I am going to replace my TAB 400 2021 tires. After reading numerous threads associated with this topic I have settled on this choice.
1)  Goodyear Endurance ST 225/75R15
Do members of the Forum still think this is an appropriate tire for this model TAB?
Thank you
  • falcon1970
    falcon1970 Member Posts: 758
    that is what I have been running for several years now.  never had an issue and they tow very well.
  • RayJim
    RayJim Member Posts: 148
    edited January 2024
    I also going to replace my tires on my 2021 400. I found that Winnebago installs Goodyear tires on their towable trailers. Winnebago Micro Minne weighs 3,300lb, same as the 400, and will be sold with Goodyear DuraTrac tires, 50psi inflation pressure. They cost around $180 each.
    2021 T@B Boondock 400. 2021 Toyota SR5 V6
  • Giota
    Giota Member Posts: 59
    Thank You!
  • Denny16
    Denny16 Member Posts: 5,430
    edited January 2024
    I think nüCamp is now using the Goodyear Endurance tire on its new trailers.
    My '18 320S came with Milestar M+S tires.  Yes, "China" tires that get so much bad press in Travel Trailer reviews.  However, I'm very happy with the quality of the Milestar's . . . . the tire is rated at 40K miles and mine are in the 35K+ range with no side wall cracks or UV light cracks - - - of course the tread is getting to the time-to-replace depth.  Just as a 40K rating would suggest.
    IMHO, all the bad press about 'China Bombs' is generated by the very large/heavy multi-axle monster trailers that are built on the cheap material wise and push the limits of weight ratings.
    The nuCamp 320 & 400 model trailers are light compared to those monsters on the road, PLUS nuCamp products are structural** well engineered and have above average build quality.
    While I have no issue with nuCamp switching to Goodyear*** brand tires . . . I see it more as a marketing issue not a real previous product quality/safety issue.
    So new nuCamp product owners don't need to rush out and replace their trailer tires.
    ** however, except for the Alde nuCamp does tend to install the
          typical lowest quality interior items.
    *** with Goodyear being an international corporation - - who designed,
         produces, inspects their trailer tires?
  • Arizonayeti
    Arizonayeti Member Posts: 27
    edited February 2024
    Due to Dexter axle warranty, I was able to get 2 new tires on my 2020 TAB 400 BL. I had discount tire put on Falken Wildpeak LT235/75R15 113R E1 AT4W.  As I frequent forest service roads, I feel better having this tire than the Goodyear Endurance.
    2020 T@B 400 BL w/solar.  TV 2018 4Runner w/ Fox 2" lift.
  • bergger
    Those are good tires and they look nice!
    2021 T@b 400 BD  "Vixen Gail"
