Cargo Rack Removal-Tab 320S
JPRoland
Member Posts: 116
Hi NuCamp friends. My Tab 320S Boondock was struck in the rear on the Interstate but fortunately was not hurt as it was protected by the cargo rack. The cargo rack is bent, however. I would like to take the rack off to re-shape it but as I started to back out the screws they won't back out. There must be a nut that's spinning on the other side but I'm not sure where to look for it. Has anyone had experience with rack removal on a Tab? Thank you.
It's not the cargo rack. It's the rack that covers the back of a Boondock and protects the lights, etc. If I could just gt it off of the RV I could repair it. Help!
Email tech@nucamprv.comSharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
Sorry I don't have specifics, but I've seen the two bolt heads with fender washers and nut somewhere inside the back curve below bed level.
2021 T@B 320S Boondock/ 2012 Tacoma 4 cylinder truck / 2023 Tacoma 6 cyl. truck -
Thank you.
- 919 Introductions
- 405 Service/Maintenance & Recall Notices
- 74 Teardrop Groups & Links
