Hello all! Trying to Dewinter our brand new 2024 Tab 320 CS-S and have a problem. Drained all antifreeze, have added bleach solution thru siphoning and filled water tank. Now the problem: went to "Dry Camp" mode and turned pump on-pump runs but water comes out overflow under camper only and no pressure to faucets. Switched over to "City Water" setting, connected hose (no pump on) and water also comes out overflow immediately. Seems to be some valve not closing I'd guess? Any advice/thoughts?
                0 ·
And soon, all of these experiences will become great campfire stories.
One thing that might be helpful is if you print out the Nautilus schematics. I found them on their website and they are informative as to what is actually happening plumbing wise during each of the settings on the P3.
We are newbies as well and are learning new things every trip. It's really fun and less intimidating now.
2022 Toyota Tacoma TRD Sport "Lunar Taco"
Chapel Hill, NC
Found this but don't know how to fix it...wanted to see what others had done.
"There is a one way check valve in the city water intake assembly which prevents water from coming out where it is supposed to go in. That valve must have failed or stuck open by debris; the water pump will push water out the city water intake if the check valve doesn't work."
