I'm hoping to start a thread here for Victron Multiplus and Multiplus II users to contribute their discoveries and modifications. I'll start this off:
Get shore power at your outlets even when the Multiplus is turned off.
I have found it annoying that in order to have120V power in my TAB, the Multiplus needs to be turned on, even if connected to shore power. Sometimes it is inconvenient to turn on the Multiplus - maybe you don't want the hum and batteries do no really need to be charged but you want to use the microwave. For about $25, I offer a simple solution:
This involves disconnecting the trailer 120V power from the Multiplus output and inserting a
120V DPDT relay into the circuit as shown. Shore Power still feeds the Multiplus input, but also feeds the trailer if the relay is
not powered. The relay is only powered if 120V is present at the Multiplus Output (either pass-thru power of inverter power) in which case the trailer power is connected to the Multiplus output as before.
This really is the beauty of these systems. We no longer lug a generator on our trips and have never gotten below 60% battery capacity.
