I am keeping the original handy to put on top of little one when we need the space. Will have a look at the friction slip solution to keep it from sliding off.
We use the factory table (2021 320S) but I shifted the mounting and drilled/screwed 2 new holes. It requires more turning in some cases but allows the table to be closer to the rear seat backs or much more available to the cook when additional space is needed. We found it a good way to get a smaller and bigger one using the same top.
Snohomish WA, 2015 Diesel Grand Cherokee Sm@ll World: 2021 320S Boondock, 6V Pb-acid Shunt, Roof & Remote solar & 30A DC-DC Chargers managed by VE Smart Network
I made the bracket slide on the original table bottom. This allows infinite adjustability and was easily accomplished by fabricating a couple slide tracks. In my case some oak molding scraps with a saw slot got the job done. They're even held in place with the original bracket's screws and I stained them to match the UT's cabinets. There are central rubber bumpers to stop the bracket from traveling too far and the black thumb screw locks it in position.
We haven’t found a reason to use it yet.
Very nice...another option to down size for the area is to make a drop leaf. We keep the OEM table outside full time.
Southern Maryland
https://www.homedepot.com/p/Husky-26-in-Hardwood-Tool-Cabinet-Top-for-Rolling-Cabinet-HOCN260001/203949843
