Would someone straighten me out...PLEASE? I have gotten myself so confused overthinking all this. I'm out camping for a few days and would like to have hot water in the galley. I have water at my site. Which tank do I fill? White hose or gray hose?  Water filter? Water pressure attachment? Turn on Alde?  And as far as draining goes, black water tank is toilet?  Gray water tank is everything else?  Does gray water tank need a special hose for drainage or can you use the same one as for the black water? I know these are a lot of questions but I've tried reading all the posts I could find on the subject but am getting myself more boggled. I have a '15 T@B CS-S Max.  Thank you for your help.
                0 ·
The water from the sink will go into the gray water holding tank, and you can use the same hose as your black to drain it.
Sterling, VA
Water:
1) Attach the water pressure valve to the hose with a blue stripe on it - it's probably white.
2) Attach water filter <- Totally optional
3) Connect hose to water source and T@B and turn on.
You should now have water. You can be sure by turning on the kitchen sink. You don't need to turn on the water pump as the hookup is providing the pressure.
Hot Water - Turn on the Alde:
1) Slider #1 up to the two lightning bolts
2) Slider #2 up to the flame (this gives you turbo boost with propane.
3) Slider #3 up to the water symbol
4) No need to set the dial, that's just for general heat like your home thermostat.
In a few minutes you should have hot water. You can test by opening the hot water valve on the sink. Be careful, the water gets really hot.
Dumping:
You have one hose. You first hook to the black water valve and drain then switch it to the gray water valve and drain. By doing it in this sequence, the gray water helps rince the hose out.
J.D. & Sue
Twee, when you first turn on your tap, it's best to let the trapped air out slowly, so you don't get a blast of water spewing. It's easier on your plumbing and your filter.
I've read (not on the forum) conflicting advice as to which end to use the regulator - what do you and others think - end by the city water hook up or the end right before the t@b inlet?
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL
John & Lori in Northern VA
Former owner of 2015 T@B CS Max "Uteki" aka "H@wk T@B"
2012 Toyota Tacoma Double Cab 4x4 Off-Road "Zame"
