Cracked Toilet base
PecksFL
Member Posts: 1
We are on our first long trip and our toilet broke completely off the base. The screws came up with the toilet and the cracked apart piece remains on the platform. Desperately need to know if that flange going into tank is glued in or screwed in.
320 or 400? Year? Cassette?
Not many photos of toilet removals on this forum. Only one I found only had a couple screws at the base.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0 -
The flange is not threaded, no telling if it was glued at the factory but I doubt it as it is not a pressurized connection. Might have some sealant though.
Looks like you just need a new toilet flange (the broke black piece attached to the floor). It appears the make and model number are imprinted on flange. Should be easy enough to order a new one. The flange appears to be secured by six screws and sealant. Remove the six screws, then use a plastic putty knife to break the sealant (plastic will protect the floor surface material). Should come right off. Good luck.2016 Outback 320
This link has the Dometic manual for that series of toilets. The flange itself is shown in the install directions, apparently it is used in the Dometic 300 series of toilets.
Towed by 2014 Touareg TDi0
